turbomoparboy
- Joined
- Jul 14, 2010
- Messages
- 22
Hi I am new to the forum. I recently purchased a 94 Bobcat 763 skid steer ( Kubota diesel) from a friend who did not need it anymore. The machine has a little under 4000 hours and runs great. The issue with the machine is the cab rotted under the seat where the insulation was. It was used for load salt in the winters. Surprisingly it is not all that rusty otherwise. I am going to cut out the piece and weld in a new piece of steel. The rest of the cab is very solid. I would like to go over the machine before I put it into use which is just for general use and snow removal around my property. I need to replace a hydraulic line because it has a slight leak so I figured I would change the fluid and filters as well. What type of fluid do you recommend for the hydraulic fluid. The repair manual says bobcat or 10-30. I would also like to replace the chain case oil. Any recommendations here and are there any adjustments? The machine came with all new bushings and pins. Is there a removable bushing in the tilt cylinder where it mounts to the coupler? I am not sure if it is out of round. The coupler was off the machine when I got it because the previous owner was going to replace the pins and bushings. The last question I have is the bucket was never removed from the coupler and one of the wedges ( one of the two that move when pulling the release handles on the coupler) is froze. The machine came with a new wedge, what do you think would be the best way to free it? Sorry for all of the questions. I have operated skid steers in the past and understand how they operate but have done very minimal repairs on them. My knowledge is in gas and diesel cars and trucks. Thanks Justin
