Thanks very much guys. That easy open sardine can access looks real nice. This machine is not going to be used to make money so I have some details to work out with the Minister of Finance but the plan is to look tomorrow. I'll let you all know how it goes. One thing. I may like to use a brush cutter somewhere along the line and I have seen some that say "standard flow". Do they work? Is that what I would use? Is this high flow conversion something that the average person would do if they wanted to do high flow tasks in the future, or is it something skidsteer.ca did because he is a pro repair type person?
I have mowed alot of brush with standard flow hydraulics. 15 gpm at 2500 psi puts somewhere in the neighbourhood of 22 to 24 hp to the attachment. And with the non turbo ls 160 with 42 hp I not sure if I'd have enough engine left over to drive the wheels and mow brush anyway.
Actually brush takes less hp to mow then thick heavy grass which tends to slow the cutter down more. if your mowing just grass, a tractor is a better choice because you get full hp to the pto. If you mowing around rock, stumps and God know what, then a skidsteer mower with hyd drive will save you a lot of busted parts.
Discuss hi flow with your dealer, for home use you likely don't "need" it, but if the budget allows, it will allow you to blow snow or mow brush at a faster speed.
If you decide to go hi flow get a ls 170 it has 10 more hp with the turbo. I would likely advise against adding the option later, If you hire it done, it would be cheaper to buy a machine with it.
I picked the kit up off ebay for $400, (there are more there) but it was made for a JD 6675? which is the same frame as mine but a different engine. I had to machine a spacer for the crank pulley and drill some new holes in the new motor mount. Instructions say 8 hours , but I'll have at least twice that in this. But I got a good buy on this loader and it only has 500 hours on it, and I'll likely keep it awhile.
I'm thinking more of stump grinding, so the wheels won't be in use.
I would say the average mechanical minded person could install the kit I have, there are no fancy tools needed other then the lathe to make the spacer, $50 to $75 at any machine shop.
I have no idea what the correct kit would cost at the NH dealer but I'm guessing $1000 to $1500, add a days shop rate on that and buying the loader with it might look pretty good.
