Needing to add antifreeze everytime I use the machine.
bu58
I just bought my first skid steer loader (don't know how I ever lived without one). It is a 2006 John Deere 317 from a local rental place with 700 hours on it. When I checked the antifreeze level, the recovery tank was almost empty. I have run the machine four days (about three hours each time) and I have had to add antifreeze each time to keep it at the proper level. Is this normal? Since the previous owner of the machine has been less than truthful about a couple of things I am starting to get paranoid. P.S. Attachments are expensive!!!!
First check the overflow tank and line for leaks. Next do a pressure test on the cooling system and if that doesn't show any leaks get a combustion gas test kit http://www.amazon.com/UVIEW-560000-Combustion-Leak-Tester/dp/B000NPDL76 and test the fluid. Also keep a close eye on the crankcase oil level to make sure the anti-freeze isn't leaking into it.
As an Amazon Associate we earn from qualifying purchases.
You can smell the anti freeze in the crank case oil or it's getting burnt out through the exhaust system and turbo (if it's got a turbo)
It could also be a tiny leak in the radiator or where the hoses connect to the engine and radiator.
"P.S. Attachments are expensive!!!!"
mine are'nt!!!
www.skidsteer.ca
Also I tend to agree with Tazza, all comments a good ones, but don't for get to look for minor problems too, as in most cases, hopefully you will find the culprit is something simple.
