Need snow chains or ideas before snow starts to fall this year.
djphelan01
I have a Bobcat s185 that I put chains on to plow my driveway. Last year one of the chains broke so I need to either buy new ones or come up with other ideas. I was thinking that I might be able to find some old truck rims and tires to put chains on. The chains might be cheaper or I might be able to get studded tires. Has anybody tried truck wheels? If so what did you use? My wheels are 8 lug 10X 16.5
I have seen a couple of guys put skinny truck tires with tread patterns that look like something straight out of the 70's. The tires are suppose to work great, but i never drove one myself. Unless you have a lot of ice, I never had a problem with standard skidsteer tires plowing. There are companies selling package deals now on snow tires and rims.
Thanks for the reply! My driveway is a hill and it gets icy . Without chains or studs I can't get get up it. I thought I saw pictures of small car like tires on a bobcat and thought that might be cheaper if I can get used ones.
Personally I would use chains before any kind of tire. There is no tire that can match chains for traction. The set I have I bought locally (mills fleet farm) for around $75. For that money I would buy a new set every year if needed and my tire size is the same as yours. The driveways I plow around here are gravel not tar. I suppose tar would be harder on chains and chains probably would leave some marks on tar also. Last winter I took my chains off when I thought the snow was over, mistake. Another storm came so I plowed without, spun sideways and landed up against a tree down a little incline and stuck I was. Cant say enough good about chains in snow.
I use two machines to plow snow with, a bobcat 600 with a 8' snow bucket (my own) and a New Holland 160 (my bosses) with a 7'6" snow plow blade. Neither one has chains, they both use skinny light truck tires in winter. They work great! No annoying chains to hassle with, yes I have in the past used chains and still have chains. I just don't want to use them, I don't need them. I admit the 600 with the snow bucket helps me get traction. If I feel like I might spin I simply lift the bucked a bit off the ground to put weight on the front tires. only lift enough to load the tires and not leave snow behind you. I leave the LT tires on all year on the 600, they are easy on the grass in the summer, don't tear up the lawn as much as skid steer tires. The 160 we plow for a large factory and privately, and when we are out it is almost over 10-12 hours each time and I complain about a lot of things, but traction is not one of them. this is in northern WI., so you know we get real snow,(deep, wet heavy, drifting you get the idea) not just light stuff. My .02 cents, no chains, skinny tires it helps to use tires that are siped, like a Blizak or similar. Here is a link to some Blizak tires. http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Blizzak+DM-V1 My 600 uses regular 16x7.00 LT snow tires.
Djphelan 01… I run an 863 with a 9' blade here in Alberta & can say that any skidsteer pushing snow up here is useless w/o chains. I always run a set on the rear only. I also run an oilfield trucking co., so I have access to plenty or half worn out truck chains. I use these to make tire chains for my skid steer as the are close enough to the right width to work great. And no… that is not my heel squeaking when I walk! lol
