Stone Hands
- Joined
- Sep 9, 2011
- Messages
- 35
New member here. Question. I have changed our all the filters on my 863 turbo except the Hydro filter. When I went to do so I first put a 4 quart plastic pail under the filter and proceeded to take off the filter. After the pail filled up to the top with fluid and the filter was still not off to replace I tightened it back up to rethink the process. My unit only has 1 filter not 2. May have had previous work on it in its past life. Do I have to drain the holding tank of fluid to change the filter or will grafity allow it to continue to drain while the filter is being changed. The Bobcat dealership said only a small amount should come out but I think a gallon is more than a little.
