6brnorma
- Joined
- Jul 13, 2011
- Messages
- 882
Going by your figures……you have a full 5" from taper shoulder to shaft end (3 7/8 + 1 1/8)? That's 3/4" longer then the longest of the other shafts… Every other measurement is the same on all of them. I made some calls for you today just to verify what your dealer told you. The #6554942 shaft is no longer available……he is going to try to get me some specs on it but wasn't very hopeful on that. "If" in fact you need a full 5" it's going to be a problem as the current M-610 shaft (#6503348) is 4 1/4". I'll let you know if he has any luck. The surface area for the drive gear certainly leaves some room for adjustment with shims but I rarely use more than a couple.Now I'm nervous about which jack shaft to order. As mentioned above the manual states #6554942 for the M444 and #6503352 for the M500. I can't find any specs on either part to compare to what I have taken out of my machine. I've attached a pic of the broken shaft with dimensions. Maybe someone out there can tell which part I have. My bobcat dealer in town says that the 6554942 is not available anymore but when I call an implement dealer in Aikin MN they say they can get either shaft but can't tell me the difference between the 2. OOF! If it's just a matter of length I feel I could shim or adjust accordingly but if it's a matter of diameter that has me worried.
