I have an lx 865. my mufler bolts right to the turbo. it could have something to do with the muffler. I recentl rebuilt my engine. I inspected my turbo and the carbon build up on the exhaut side was rubbing the fin on the blower. It wouldnt take much to stop it from spinning.
the book says the turbo has to be dealer serviced. I had to either take mine apart and clean it or replace it. my dealer said they dont mess with them. Buy a new one they told me. I decided to take it apart and clean it They have some wierd nuts holding the blowers on the shaft. Its not to hard to get it apart. The blowers are delicate. I cleaned out all the carbon and inpected the bronze bushings. They werent real tight but didnt look worn The shaft floats on oil as you have an oil line going directly to the bearings..
The book gives specs for clearances for end play and bushing. I cant remember them but they werent real tight. The beonze bearings had sholders to control end play.
So I just cleaned and reassembled. You cant buy parts. I had a little noise for about 10 minnuts.[Little rubbing] Its not complicated. Im sure ballance is an issue with them not wanting you taking them appart. I have about 50 hours on it now. It seems fine.
I would give it a spin with my finger when you get your muffler off. You should be able to feel anything rough or sloppy. I was afraid to spray carb cleaner in mine. I didnt want to get loose carbon in the bearings. Mike
