lx865 turbo help
Fordman0602
so the skid steer runs fine going forward no sluggish or chattering. when i go in reverse the right side hardly moves and the hydraulic temp alarm goes off. once i let off it stop beeping a few sec after.
The arm attached to the right hydro pintle shaft runs close to the temp sender. If the arm is loose on the shaft the arm is hitting the sender limiting the arms travel and shorting the sender.
