i have an lx865. i was leaking hydro oil into the gear case where the pumps bolt on. I removed both pumps and replaced the shaft seal on both of them. I did not have to take the pumps apart as only a retaining ring held the shafts in place. so it was quite easy to pull the shaft out and put new seals in. Reassembled everything. Now my problem is i have no steering on either side. the boom hydraulics work fine and the pumps for those are driven by the same shaft that drives the steering pumps. I have tried bleeding the lines for hours and hours. i assume there has to air pumps. what i've tried so far is: overfilling the tank to get gravity on my side, cracked all lines one at a time to let air escape while running. Im out of ideas! i've also taken a line off and manually turned the tires to try and draw fluid thru. any help would be greatly appreciated.
