tech.35058
- Joined
- Dec 15, 2016
- Messages
- 80
The air filter indicator lamp on my LX865 comes on after the machine has run for a bit.
Of course I changed the air filter elements, but the situation remains, after the machine has run for a bit, the light comes on. I went skimming through the service manual, but I did not find references or specifications for what pressures ( vacuum level) triggers the light. While I might just replace the pressure (vacuum) switch, I would prefer to verify the problem first. Can anyone share the switch open close vacuum pressure?
Can any one share specs on "normal/acceptable" air filter vacuum?
"normal/acceptable" turbo boost?
Thanks, CE
Thanks, CE
