Looking at an LS160/170 wiring diagram (very little difference vs the LX series), looks like the trigger signal for the relay comes in on a Light blue/yellow wire coming from the #2 pin of the larger connector on the back of the board in the dash. Suggest checking continuity through that wire/corrosion at the ends, etc. I'd also check/clean grounds and battery connections just to be sure.
