Still working on getting the LX665 up and running that has had hydro issues. Now it appears I have some issue with the governor. Engine is freshly rebuilt top to bottom with a good turbo and reman injectors. Engine bogs easily. When I drive up a large hill at say 1/4 throttle, engine will start to bog down(which is normal) As I continue to drive I will reach over and push the throttle up to full throttle, but nothing happens. If I stop forward movement(and take load off engine) the engine RPM picks up to full throttle, and I can go right up the hill no problem. If I put the engine at full throttle before I go up the hill the machine will go up the hill without a problem. It appears the the governor isn't giving the engine more full to maintain RPM under load. I did switch out pumps to another used pump to see if that made a difference, but it didn't. Any ideas?
