Mike10, this might be one for you.... I have an LS180 that was running fine and all of a sudden the engine shut off. Lost all electrical. No dash,lights etc etc. I have battery voltage over to starter. From the starter the line runs to the rear fuse panel right? I didnt get a chance to check voltage there. I suspect I have a corrosion or broken wire. When I first got the machine a few weeks ago the headlights wouldnt work. No power to the relay. I unbolted the main fuse box and was poking around and all of a sudden I got voltage to the relay and everything has been fine since then. Is there any way to easily repair the wiring to the fuse block? If I remember correctly the wire was crimped onto the metal that goes to the incomming side of all the fuses.
