Is the adjustment the large arm on the pump? Sorry, new to this...Block it up lift the cab and ajust
Could a bad motor mount cause it to come outta whak? Mine would spin slightly while sitting idle. A single hole strap broke which led to a hose rubbing a hole in itself. After i fixed the hose and strap the spinning went away. This was at @ 1100 hours. The broken clamp was under the seat, bolted to the corner of the valve body.Is the adjustment the large arm on the pump? Sorry, new to this...
