Looking for a crankshaft still
briguy98
I am looking for a rebuilt or good used crankshaft and can't get back to work until I get her back running. I need a good place to go to and get everything I need such as bearing, gaskets,starter...etc
i looked all over for this crank (used) nothing...new ones $2200.00 even if you try to repower this unit with a different engine you'll spend the same or more for a quality used engine. you say your in pa i assume you called messicks, maby try b & r in beaver springs or C S snyder around the tamaqua area. sorry cant do anymore. watch ebay maby you'll get lucky
Have a look at agparts , they have rebuild kits and some aftermarket cranks. Look at 87 and up Ford / New Holland farm tractors as these use a engine very similar to the skid motor. The skid is a 332T / JF , the farm tractors use a BSD332. ( This basic engine goes back to the 60's ) Also try www.crosscreektractor.com/customer/crcrtr/pdf/Ford.pdf
Thank you very much. I did find the same answer from a company called Wengers in Myerstown Pa. I just received all my new parts...I will let you know when the machine starts to run again.
