I have an F model 753. Recently tore it down to repair crack in lower frame. All worked fine. When i re assembled it the lift arms and bucket would not move. BICS code says grounded circuit or no ground on the lift arm lockout. Replaced lockout solenoid coil, inspected valve was working properly, checked and cleaned all ground i could find, tested for continuity and power at harness plug and checked secure connection at all connectors. I even tried unhooking the battery for a while to hopefully "reset" the BICS. Still nothing. Machine drives around fine just no lift arm or bucket operation. Any help would be appreciated.
