Leak on Wheel drive motor
Jbohannon
I have a Mustang 2050 that shoots fluid out the side of the drive motor when under pressure and a little flow under no pressure. can this be repaired ?
Is it leaking between the segments of the motor?if so, it could just be a bad Oring.
If nothing is cracked, it should just need seals. If it is damaged, hopefully loader parts source can hook you up with the required parts.
