Laser level set ups?
garrett2006
looking to see if anyone has a video or write up on using a rotary lever on a skid steer bucket or blade. Not the auto level grading attachments you can buy, but something someone has fabricated to work on there bucket or box blade. World like more info on this topic from guys using it this way. Also, what brand laser system are you using. Thanks
The simplest setup is a mast mount on the bucket with a receiver to track grade.
If you have not purchased a rotating laser yet, look closely at the available receivers. When I looked into them years back, the receivers I liked would not work with the rotating laser I had.
Apache, Leica (Depthmaster) and Spectra Precision make receivers that are designed for mounting to equipment.
You can also mount the receiver to the loader. It will remove a lot of receiver vibration and is less likely to be damaged compared to a mast on the bucket.
You may also want to invest in an elevating tripod for your laser.
