Rayhat
- Joined
- Nov 17, 2014
- Messages
- 28
Can anyone tell me why this “pump to final drive” line starts out in hard pipe goes away from the final drive motor under the hydraulic pump, does a 180 degree turn ,connects to a larger diameter Hose and then goes to the drive. The end to end connections are just a foot away from each other but they added another 8 inches and changed the direction and then increased hose diameter from pipe diameter. Can I just replace this with a larger like size diameter hose with some slack. I had to cut the pipe so as to not remove the pumps to get it out. The cuts are at the electric tape holding it in position for the picture. It’s line 18/19 in the diagram and if the video loads you can see the leak at the fitting.
