So after fitting my cheap copy fuel sender i decided to fill the fuel tank up to full, anyway it took a lot of diesel and then i found out why as it was pouring out from underneath! After investiagtion i think it might be where the the filler pipe meets the tank as it has a rubber hose 3" which has marks looking like it should have 2 jubillee clips on securing the filler tube to the tank. The problem is that it sits mainly behind the metal plate behind the seat which cant be moved. Would i need to drop the tank to put these jubilee clips on? I am not keen to drop the tank as it is plastic and 33 years old so i presume will be brittle....? i might just have to leave it
