L220 starter replacement
Gracecon1
So, I feel like I might be screwed. My starter quit on the skid steer and I can’t get it started to lift the boom and roll the cab. Is this possible to change from the back or cab? Thanks in advance for any help.
I don't know these machines, but there has to be a way. I have even heard of people hooking up a hydraulic power pack to t a lift cylinder to lift it up when a battery has failed and access was an issue.
This is what I did on mine different model but boom still has to be u[. I took the bucket off the skid steer and them used my tractor and loader to raise the boom on the skid steer. Now you have to have someone in the skid steer to hold the boom control in the up position or you will just raise the skid steer. Once you get it up past the boom locks you are set to go. Good luck and be safe
Little late to reply, but for others' info, my NH 185 has two large terminals, lower left that can be accessed and used to jump the battery after opening the back radiator grille. Don't know how many years or models had this feature.
Sorry, just saw OP has a starter problem, not a battery problem.
