2010 L180 only 80 hours. Operated fine, stalled, and wont start. Seat switch lights up control panel, seat belt light goes out when clicked. Cranks fine, but wont fire. Fluids are full. Any advice would help..
Be sure the aux control handle is in the neutral positon. This is the handle, on foot control models, that controls oil flow to the boom couplers. Hand control units use a handle in front of you on the cover over the control valve that locks the pedel in neutral. You might try moving it slowly back and forth while cranking to see if it will start. When the handle is not in neutral and you try and start all the engine will do is crank.
I guess you checked your fuel level.
