l 565 WATER PUMP
larry wv
Hello guys New fellow here from western wv along the ohio river. The water pump is bad on our l565 new holland skid steer. Do I need to remove the radiator and oil cooler and go in from the back side to get the pump off? Also will I have a problem with air in the hydraulic system if I need to remove the oil cooler? Been trying to figure this out with out going in blind. Thanks Larry
I have done it without removing the radiator or cooler but I think it is easier to remove the radiator and cooler and you will have a lot less skinned knuckles and hands. You do not have to worry about air in the hyd system, it will clear itself.
Thanks mike 10 appreciate the info. Larry
