L 553 warning buzzer
Ivan
My warning buzzer only works sometime. Where is it located and could it be an electrical connection loose. Thanks Ivan
The buzzer is located behind the instrument panel. Lower the panel and I believe it is on the left side. If I remember right it is a retangular box. It probably is the buzzer causing the problem.
Thanks will check it out tomorrow.
Mike where is the buzzer on the lx 665? Mine has never worked, one time I had the eic display out it looked like might be on the left end of the board but did not have time to look into it then.
That is the alarm, however, it is not replacable, like the L553, unless you have the instrument panel repaired.
