Thanks will check it out tomorrow.The buzzer is located behind the instrument panel. Lower the panel and I believe it is on the left side. If I remember right it is a retangular box. It probably is the buzzer causing the problem.
Mike where is the buzzer on the lx 665? Mine has never worked, one time I had the eic display out it looked like might be on the left end of the board but did not have time to look into it then.Thanks will check it out tomorrow.
That is the alarm, however, it is not replacable, like the L553, unless you have the instrument panel repaired.Mike where is the buzzer on the lx 665? Mine has never worked, one time I had the eic display out it looked like might be on the left end of the board but did not have time to look into it then.
Thanks MikeThat is the alarm, however, it is not replacable, like the L553, unless you have the instrument panel repaired.
