Kubota V3307 engine parts
larabeejj
I have a 2019 TL10V2 engine assembly that was running but had a tapping noise in the engine when I bought it used. I swaped out the motor. Message me if you need any parts from the motor. I have fuel supply pump, injectors, engine harness, DPF etc. [email protected]
Did yours have àc? My machine had the ac removed before I got it and I want to put it back on. I need the bracket and compressor for sure and most likely everything else. I have found a couple of brackets but I'm not sure which one I need. Could you possibly get me a picture of the bracket?
Yes the machine came with AC and to my surprise, it worked. Give me a few, I'll get some pics for you.
Thanks! For some reason, the previous owners removed the heater and ac, but all the controls and vents are still there. I can't figure out why they would do this on a machine that only has 2100 hours on it.
Hey RS. Snow storm slowed me down. Attached are some bracket and mount photos. Holler if you need measurements or specific photos.
You did good, thank you very much. That is different than what I saw but then again I'm not sure if they were correct. That doesn't look to hard to make and I could even make the adjustment into the bracket. This gets my mind to working.
