Kill switch?
Have a Gehl 3610. Starts fine but it won't shut off when you turn the key off. Is there a way to put in a toggle switch that will shut off the engine or fuel pump to shut it off? If so how would i do it? i usually drop the bucket and down throttle to shut it down.
Moved to the Gehl forum so it should be seen by others with this model.
Not familiar with it myself, but if it has a fuel solenoid it should be able to be wired into the key switch, if it doesn't it might need a cable pull shutoff like the 743 used.
