Tazza nailed it. If you use a smaller auger you should be ok. Just don't expect to be tossing dirt 6ft in the air.... As far as your other questions...That's exactly what that lever does. It controls the travel speed by varying the width of the drive pulley. The higher it rides the faster the machine goes, but the less torque you have. The lower it rides, the slower it goes, but more torque is available. The "device" that is leaking is either a fuel bowl or fuel pump. If it has a glass bowl on it, it's a fuel bowl. If so, get rid of it and put a large inline filter on it between the tank and fuel pump. Any autoparts store carries them in metal or plastic. I have a plastic one so I can see fuel flow and watch for water accumulation and dirt buildup. The fuel pump is round, all aluminum, and has like 10 screws(not sure offhand) around the top of it, and bolts right to the engine. If the engine is running good, and the carb itself isn't leaking, I would leave it alone. As far as a price on a muffler, it varies. You can check the local farm stores, tractor places, or have a look on eBay. Hopefully this helps.
