John Deere 6675 skid steer fuel tank leak
I also have the same question as you Dave but mine is with an 8875. I really hope the answer isn't to pull the engine but from what I can see there doesn't seem to any other way. Hopefully someone has already gone through this and can help us out
I think the 6675 is the same machine as the 665 new holland and looking in the book I see nothing listed for fuel tank removal. If you remove the back belly pan will it come out underneath? Too cold to go out and look here.
1. Raise the boom, extend the boom lock pins, 1,
and lower the boom down on the lock pins.
2. Stop the engine, turn the ignition key to the "ON"
position and operate the boom and bucket
control pedals to relieve pressure in the
cylinders, turn the key "OFF."
3. Jack and securely support the loader up off the
ground approximately 20​
(508 mm).
4. Remove the engine area belly pan, 2.
5. Remove the left fender, 3.
150
6. Open rear door, 1, raise the top shield, 2, and
remove the left side shield.
7. Remove the fill neck retaining hose clamp or
screw at the tank and remove fill neck, 3.
8. Unhook the suction fuel line, 4, and return fuel
line, 5.
9. Remove the wires from the fuel level sender, 6.
10. Remove the lower engine fuse panel support
hardware, 7, and move the panel up.
151
11. Remove the connecting hose, 1, and drain the
fuel tank into a clean container.
12. Remove the front, 2, and rear, 3, tank support
hardware.
13. Remove the fuel tank from the bottom of the
engine compartment.​
152
this is from the 665 manual, same as 160 and I believe jd was the same till 2000
″ (508 mm).
150
line, 5.
151
hardware.
engine compartment.
152
Thank you very much. I did not know if removing the belly pan would get it out. Possibly, my problem is only with the connecting hose and removing the pan would let me get at that. Thanks again Dave
If it helps I was able to get the tank out on my 8875. Had to tilt the cab and end up jacking up the rear of machine but it finally came out. I realize your machine is different but, you would think they might be engineered to work the same way. Good luck
