I have a 2002 deere 270 and the 12v wire #500 on print behind the park switch is getting hot when hydraulics are unlocked the amp draw is 16 amps on power wire and wire 721 not sure what the amp draw should be or if one of the hydraulic lock solenoids may be pulling too much it has a 25amp fuse but just looking for ideas if this is normal I added about 3 inches of 12 ga wire from switch connectors back to harness that helped with wires getting hot but still drawing 16 amps not sure what to do. I have pic of print but could not add to post for some reason
