I am not familiar with your unit. On mine, there is a door sensor that will lock out the bucket and boom if the door is open. When mine did what you described, I had to replace the solenoids for the hydraulics. FYI the boom and bucket solenoids should be 14.0 - 18.5 ohms. Finally, mine has a rocker switch that allows the unit to be operated when out of the seat ( for accessories like log splitters and backhoes). It bypasses the safety switches as another way to troubleshoot the problem. Think Safety switches first, electrical (fuses, relays, switches, solenoids, weak battery) then mechanical (pump, broken pins, etc). Good luck.
