hydro to pto
dlong
Does anyone know where to get a hydraulic motor out to pto shaft unit?I know they are made just dont know where to look,Thanks
There are a couple of companies that make a 3 pt. hitch with hydraulic motor set up. They come complete with the quick attach plate that has adjustable 3pt. hitch attach and a hydraulic motor set up to take your PTO shaft with no alterations to the shaft. The cost is about $1,800.00. Search the Skid steer attachment companies on the web. If you want to build one, you can use a spider link (hub for each shaft with a rubber link between them) between the motor and shaft to make the hook up. Any good bearing or gear distributor should be able to help. Joe
www.surpluscenter.com has a pto male stub shaft that fits onto a hyd motor output shaft and a good selection of hyd motors in all diplacements so you ca achieve the diseired rpm.
