Hydraulics Uniloader 1830
Toma46100
Good evening What is that there is a relation enter the hydraulic reservoir of my 1830 uniloader and both blocks of the transmission by chaine??? Because I have a flight(leak) in the crankcase of left(awkward) transmission and I has to fill(perform) the hydraulic reservoir which empties!!! Thank you
I wish to know if there is communication between the hydraulic reservoir and the crankcase where there is the chaines of wheels??? Case 1830 Uniloader
In short,Yes
You likely have a seal leaking on the hydraulic motor that drives the chain on that side of the machine. It is letting oil escape around the output shaft and the output shaft extends into the chaincase, so the oil is leaking into the chaincase. The chain case should be overfilled if this senario is true.
In short,Yes
Thank you for your answer The crankcase of chain is filled with oil!!! I thus has to change the SEAL spy to the axis of the engine. My question is the following one; the crankcase of chain must be filled with oil or he must be empty ??? Where I can buy the seal of the hydraulic engine, the delivery in France???? Thanks
