I found that this plate was bent, almost like there was downward pressure on the top of the shaft that push the o ring out enough to leak. I noticed if you turn the pump on it's side there is some play back and forth in this pump. Not a lot but some. The cam plate had been riding on top of the shaft in the front and back. Wore spots on the yellow adjustment (neutral cam plate #12). This unit only had one guide on the left side, right was missing.
I'm going to make a thicker plate, add some longer screws, replace the o rings and seals on top. I think this will stop the leak. Readjust all the blocks so they don't rub the top of shafts.
Thanks to everyone, the pump drawings were a great help. I appreciate all you inputs.
