Hydraulic Oil Choices
hevmetl
The manual says Mobil DTE 15M this is ridiculous to find! What is a good alternative Thanks in advance
Depends on your average ambient temperature range as to what grade you will use, but generally any HYDRAULIC OIL that has an "ISO-AW" rating will be adequate. If you operate in a mild temperate zone you may want to consider a multi-vis hydraulic oil. My Mustang manual specifies ISO AW46 for the hydraulic system and the chain cases. I use a multi-vis oil ISO AW32/46/68.
