dogfishlake
- Joined
- Jan 15, 2011
- Messages
- 13
Does anyone know a part number to replace the mustang hydraulic filters #170-33635? Golden Eagle parts doesn't show this one available anymore. Thanks in advance.
Close Window |
All Applications | |||||||||||||
Style: | Spin-On Transmission Filter | ||||||||||||
Service: | Hyd/Transmission | ||||||||||||
Type: | Full Flow | ||||||||||||
Media: | Paper | ||||||||||||
Height: | 7.803 | ||||||||||||
Outer Diameter Top: | 3.698 | ||||||||||||
Outer Diameter Bottom: | Closed | ||||||||||||
Thread Size: | 1 1/2-16 | ||||||||||||
By-Pass Valve Setting-PSI: | None | ||||||||||||
Beta Ratio: | 2/20=2/11 | ||||||||||||
Burst Pressure-PSI: | 600 | ||||||||||||
Max Flow Rate: | 28-30 GPM | ||||||||||||
Nominal Micron Rating: | 5 | ||||||||||||
That is perfect. THANKS!It crosses to Wix # 51202
If wix has it likely other filter companys will to.
zoom
Part Number:
51202
UPC Number:
765809512023
Principal Application:
Case, Cat/Towmotor, IHC, Galion, Gehl, Koehring, P&H, Other
All Applications
Style:
Service:
Hyd/Transmission
Type:
Full Flow
Media:
Paper
Height:
7.803
Outer Diameter Top:
3.698
Closed
Thread Size:
1 1/2-16
None
Beta Ratio:
2/20=2/11
Burst Pressure-PSI:
600
Max Flow Rate:
28-30 GPM
5
Gasket Diameters
Number
O.D.
I.D.
Thk.
Attached
3.431
2.963
0.218
Close Window
