hydramac 12c hydraulic fluid
mac12
I need to know what kind of hydraulic fluid my machine takes. Will iso68 work or is that to thick. I'm not sure what it takes so any information will be much appreciated. Thanks in advanced
Hi I have 14-c and my manual calls for automatic transmission fluid (dextron) check the color befour you add any. I changed mine over to a tractor hyd trans. fluid from tractor supply. TOM
WOULD hydraulic fluid ISO 68 work. Its sae 20. From runnings
I'm sure it WOULD work, but is it the rite fluid? That's what Tom is trying to say.
No one wants to say yes, it will be fine, as if something was to go wrong and it was not exactly as the manufacture recommended, you may be a little upset.
If it's too thick it will be hard on the machine when it's cold, if it's too thin, it may cause damage in the heat.
