how to time hydraulic drive motor 743
jackrabbit
I need to time hydraulic drive motor on 743b bobcat # 6657024 is this a eaton motor & what series & does it time The same way as the 743 4000 series motor I couldn't find the same motor on eatons web site
Finally found what brand my drive motor is .Made by eaton repair information no.7-149 25 series vis bearingless motor Parts information no. 6-151 vis bearingless motor this is what you need to work on these motors Go to eatons web site type in no.
After finding it, did you get it timed correctly?
HEY TAZZ. I myself have never found a definitive answer to this yes big case drain hole to largest port. I have gotten wrong more than I have gotten it right, retime motor hell no cross hoses hell yes. I suppose the issue arises a . book does not differanate left or right motor. in my expearince. seems to me as to which motor starts. my solution. wheels off ground bungee sticks fwd. fire it up.should be right. THE problem being. is don't always work. than you have to cross hoses.A. makes it pain for next guy.B sometimes hoses don't fit.. randy m could not answer this queston.? my trick seems to work. but still no definitive answer . one would think that after rebuild at the very least thirty or so. of these. it should be self apperant. am I missing something?
I don't like timing motors either, looking at the holes is hard to know for sure what the biggest one is to line up, you just hope it's right.
