Does anyone have a wiring diagram for the Right Auxiliary Four-Switch? We are having a problem with auxiliary hydraulics not working due to a bad switch. The wires connecting the switch to the wiring harness are not detachable. To replace the switch, the wires must be removed from the plug itself (at the wiring harness under the cab) so that the old switch can be pulled out of the control lever then the wires on the new switch fed back down through the control lever and inserted into the plug. There are pins attached to the ends of the wires inserted into the plug. We want to be sure that each wire is inserted into its correct location.
If anyone has such a diagram, or if anyone could take a photo of the plugs so that we could confirm that our reassembly is correct we would greatly appreciate it.
