tzerambo
- Joined
- Dec 6, 2023
- Messages
- 12
I have a 763 bobcat and i replaced my alternator yesterday because it was not charging correctly. I also went ahead and did a full service. Oil change,hydro fluid and filter change and fuel filter change. Machine ran great after I serviced it and replaced the alternator and it was charging correctly. Today I went to start my machine to use it and it fired right up but I can't use my hydraulics because the bics has no power. The machine
runs and is charging correctly. Both My positive and negative terminals are clean and tight. My fuses are all good none are blown and my connectors are all connected. I took my bics off to my sure it was connected and it is. I have learned that if I disconnect my negative terminal then re-connect it my bics will light up and work until I press the operate button. Then it goes out. Then after I turn the key off and back on it has no power unless I disconnect and connect my battery then it does the same thing has power until I press the operate button then no power.
Any thoughts? Is it possible the bics is going bad??
