Head bolts
tjc
Just put a new head on my 743 bobcat I went a little out of sequence when torquing down the bolt's 1 3 instead of 3 1 before I caught my mistake will that be a problem?
you could retorque your last round again in the right order ,if you have the type head gasket that requires a retorqueing after you run the engine a few hours and you see no problems in the oil (coolant) then do your retorqueing in the correct order and call it good.
I would guess around 25 to 50 hours and do your rebuilds first oil change.
with just a head gasket and valve setting ,check your oil for coolant if all looks good go to your normal hours between changes .
