Gehl 4635
Chris201000
I've got a start issue. Bending engages but won't turnover. Battery checked, good. Starter checked, good. What am I missing? Can a bad altinator cause this?
can you get bar or wrench on crank bolt and turn engine over that way if not you can pull glow plugs to relieve compression and see if it turns easily that way. make sure if you do this the engine fuel is off.
