Fuse and relay panel question 753g. Low hydraulic pressure warning again
Vintagecarlover
So I bought a 753g with stupid low hours but sat for 15 yrs before I bought it so it has seal issues. Fixed spool seals now will need wheel seals soon but have almost constant low pressure hyd warning and shut down. First time or two reseated the relays and got everything to work but it's every time now using it and yesterday couldn't get it to move at all and shutting down. Gonna find new relays and hoping Napa has them. Anyone know which to buy? No close bobcat dealer here. Also any chemicals I can use to restore the relay panel? Clean contacts and maybe coat the relay pins with nolox? Any suggestions appreciated. -also anything else I should do or check. Issue is definitely not low pressure.
Napa ar272. You may need to redo the connectors in the panel. Ours had some loose spades that hooked to the relay pulled them out and pinched them tighter
