Fuel system pulls air for first 10 minutes
MarkCherv
2005 S300 skid steer. Primer bulb keeps losing prime. I'll prime it, turn over ignition, fires right up. But starts to die within 10 seconds unless I run back and continually squeeze the primer bulb. If I sit there for like 10 minutes squeezing the primer bulb with the engine running, it eventually grabs and runs with no problem with no more primer bulb needed. Put a fresh fuel filter, no difference. Suggestions? Thanks in advance for any help.
It must be a restriction, have you tried putting more fuel in the tank to see perhaps if your pickup tube possibly has a crack?
Yea, no change. Last time I ran it, it was still running but not as smooth as it should for lack of fuel (this was after continually priming it for 10 minutes). I heard a settle clunk like something released, and it instantly started running ok.
