Fuel leak
trutecfarmboy
I have a New Holland L553 that recently developed a fuel leak. The fuel drips off the right side of the bottom pan. Inspecting from the engine compartment I don't see a leak. I'm wonderiing what is the best way to get to the fuel tank? Thanks---Mike
I removed the seat assembly and found that the fuel appears to be leaking from the fitting on the top of the tank [right side] I'm not sure what this attaches to. Will investigate more.
After investigating more, I found the return line from the injector to the tank had a hole. I repaired and now it is ok.
