- Joined
- Jun 27, 2024
- Messages
- 63
1989 L785 with ~7,800 hours
Recently developed a leak on my NH L785.
Found leak evidence around the oil pan gasket with most concentrated at the rear of the engine.
Replaced the oil pan gasket which significantly reduced the amount of oil being lost.
But still have a leak where the engine/hydraulic pump connect.
As it is appears to be fresh oil, from the replacement of the gasket, I am assuming it is the rear main seal.
- Not a steady stream, but several drips per minute (see attached) my guess would be about a quart of oil per day. So nothing I cannot manage for the time being.
Machine uses 10-30 for hydraulic fluid, COULD there be a leak in the hydraulic system that I am just not seeing, any recommendations on how to further isolate the leak?
ONLY leaks when running, ie shut down, leak stops relatively quickly.
It appears no one has ever been in this engine before.
The engine DOES have some blow by pressure in the oil pan, BUT, i added a pressure relief fitting/filter in the unused dipstick port to relieve pressure buildup which helped also.
If consensus is rear main seal is culprit, I will likely baby the machine for this summer (to many projects to get done) and then do a complete rebuild on the engine over winter, to account for the engine blow by AND the rear main seal at the same time.
If there is a leak source I am overlooking, I will try to locate them immediately.
Thank you in advance for any/all support/thoughts.
