For Sale L555
Peoples16127
I bought this loader not running, I have rebuilt the Perkins engine, new hydraulic pump, new dump cylinder, new hoses, new quick attach, etc. If you want more details keep reading.
Located in Grove City Pa
New Holland L555
I bought this loader as a project, and I fixed/repaired/replaced with the approach that I would keep it for myself. Everything works the way it should, it has good lifting capability, and the travel works well. The paint on the machine is original other than a few pieces that I painted black to stop corrosion. All of the covers and belly pans are in place.
Design specifications
Engine:
Manufacturer: Perkins
Model: 4.108
Horsepower: 42 hp
Cubic Inch Displacement: 113
Dimensions & Capacity:
Rated Operating Capacity: Approximately 1,700 lbs.
Operating Weight: Approximately 4,765 lbs.
Bucket Hinge Pin Height: 111.0 inches
Dump Height: 89.0 inches
Ground Clearance: 6.6 inches
Height to Top of ROPS: 73.0 inches
Width Over Tires: 62.7 inches
Length with Standard Bucket: 124.8 inches
Engine
Full engine rebuild, including rebuilt head with all new valves, springs and glow plugs, all new pistons/sleeves/rings, all new bearings/gaskets/seals, rebuilt injection pump and injectors, new exhaust, new block heater, new flex plate (flywheel)
Electrical
New gear reduction starter, new gauges, new alternator, new battery disconnect, new wiring, new battery, new LED lights
LIft
Updated to standard quick attach, new hydraulic pump, new bucket (66"), new bucket cylinder, several new hydraulic hoses
Controls
Rebuilt parking brake, rebuilt steering levers, repaired rims, installed used tires (new tubes),
All fluids and filters are new.
NO emissions equipment (DEF, EGR, Catalytic Convertor), NO computers, ONE safety interlock (seat switch to boom hydraulics), NH Shop manuals included
