flow
ricklanp
I have a problem with my snowblower on a new t66 bobcat I hope someone can help me out. the problem is my blower is running backwards is there a switch that I can use to change the flow or do I have to change the connection 0n the hoses ? thank you for the help
You should be able to change the connections but usually they wont run in reverse if it is a multifunction unit, meaning using electric over hydraulic for chute rotate and deflector tilt. What make blower is it and do use the electrical 7 pin connection?
