flat face couplers
jeffb
hello to all. the question i have is, can anyone tell me where i can get a set of flat face couplers for a 99 773f other than bc dealer? i cannot get the ones on my machine to connect to the attachments even after bleeding the hydraulic system. the dealer price seems waay too high i think, i may be wrong. thanks in advance. Jeff
Ebay, baileynet.com or other qaulity hydraulic shops.
Just known as a 1/2" flat faced skidsteer coupler, "Faster" compatible.
Careful of the "Parker" ones as Case used (5 to 10 years back) them for awhile and they are different
I've gotten them here http://www.hydraulicstore.com/couplers.html
thanks for your help on this. i will contact those companies to make sure i get the right one. does the 1/2" refer to the end that screws on the fitting with the O ring? thanks again. Jeff
The 1/2" refers to the coupler size. 1/2" is also called ISO 12.5. The thread where the oring seal is a SAE size and you should measure that before ordering. As an example a ISO 12.5 Faster brand coupling with a 1 1/16" SAE thread would be 2FFI12-34SAE with a M or F at the end depending on if its male or female.
Here a link to the Faster catalog.
http://www.faster.it/images/stories/cataloghi/0113_flat_face_en.pdf
thanks OldMachinist. the stamping on the ones i have say: 2ffj12...f 8f, and 2ffj12...pm. i didn't see those numbers in the catalog but i will look again. i didn't know wether SAE or NPT so thanks for clearing that up also. i will definitely get on the phone today to get the ball rolling, yardwork piling up. thanks again guys for all your help. you guys really know your stuff. Jeff
