Economical Rear Auxillary Hydraulics
screwpiler
I'm needing to install rear auxiliary hydraulics on my S750 Bobcat. My local Bobcat dealership quoted me $4900 for the complete kit installed. The unfortunate fact is that I don't that much money to put towards that at this time. Do you know of cheaper options or maybe a less user friendly option that would be cheaper?
Very long hoses coupled to the front aux port and ran back. Apples to oranges, but a lot of guys do just the reverse on compact tractors to get front aux on their loaders.
That is my answer of last resort. I need the front auxiliaries for my pile motor but I think I could get by with using only one of the front or rear functions at a time.
Just run some T's into the front hydraulics and run new lines to the back. That or the first suggestion to use long lines and plug into the front hydraulics.
I need to put rear stabilizers on. The reason I need rear stabilizers is so I can put more weight on the drill bit when drilling hard or frozen ground.
That is a very good reason to have them. Worst case, get a helper to use a bottle jack at the read of the machine when drilling.
I was drilling holes in shale for a shed, my dad put a bottle jack under the rear of the engine as far back as possible. This way I could push as hard as I could to cut through the rock.
